Dtaylor
Oct 14, 2013Explorer
If you are trying to get hot water from electric (shore power) it takes a loooong time to heat. Yours being a little older, I am not familiar, but either outside behind the screen, or a switch on the panel that tells you tank levels should be a switch to run on gas. MAKE SURE YOU HAVE WATER IN TANK. To do this, connect water hose to to your city water connection (make sure you use a pressure regulator) open the screen cover for water heater an open relief valve till water comes out. If no water, find the bypass valve
If you have not done so, turn on the gas and light a burner on stovetop to bleed air from the gas lines
