Deb_and_Ed_M's avatar
Deb_and_Ed_M
Explorer II
Oct 15, 2014
Questions from a Newbie
OK - I've been reading and using the search feature - but am still confused about the "anatomy" of a TC.
A little background: We started with a 2004 28' Class C 10 yrs ago; then last year bought a 28' 5er with a slide, to spend some time in FL. Our business needs a heavy duty truck anyway, so we have a 2012 long bed F-350 SW Diesel to pull the 5er. We've decided that having a smaller, nimbler place to sleep for short jaunts/weekend visits would be ideal, so will sell the Class C and purchase a used, "minimalist" pop-up TC. That way I can fit in National Forest campgrounds with my kayaking pals, for starters :-)
So I've noticed that some TCs hang over the back of the truck: is that where holding tanks are located? What is that called? A "skirt with taillights"? If a TC doesn't have that rear part, does that mean it's a porta-potty-only model? But even Portapotty models still have a sink, so where are the fresh and gray tanks located?? I've also read about "basements" - I'm assuming that is a space between the interior floor of the camper and its base?
I've already read that we'll need to build a truck bed floor around the 5th wheel rails - easy-peasy.
At first, we thought about downsizing to a Class B; but the simplicity of a TC (and knowing we'll always have a truck available) makes it the smarter choice for us.
Thanks for your help!
Deb
  • The overhang may or may not have tanks. Just depends on the manufacturer where they place the tanks and the length of the camper as to whether or not the camper hangs over or not. The bigger the camper, the more "stuff" inside. Campers that fit entirely in the bed, in the case of a longbed truck, 8', can have full baths which most often are "wet" baths, that is the shower area and sink are shared with the loo. You're right about "basement".
    You're talking about purchasing a pop-up which will have limitations but they can come with quite a few of the features that are also found in bigger hardsides.
    Go to an RV dealer that carries Palomino, or Four Wheel for example. Leave your wallet home but let them take you through one and answer your questions.
