Bedlam
Jan 10, 2015Moderator
1. Some lifts use a softer spring rate than stock and you get more suspension compression when loaded causing rear sag or excessive bounce.
2. Some larger off-road tires do not have the same weight rating as your stock ones since they are designed to run at lower pressures with compliant sidewalls.
3. Taller tires may affect your final drive ratio enough that power will suffer and you will need to swap out your axle gears.
44,068 PostsLatest Activity: Jun 10, 2026
