VintageRacer
Jan 11, 2015Explorer
Everyone knows the obvious drawbacks to lifted trucks, and many with 3500's actually look to lower them for towing, so I won't go there. Once you get the lift sorted the way you want it, you need to fully and completely adjust the weight distributing hitch. You may need to find a real high quality dropped hitch head, mine is adjusted to it's lowest point to fit my stock height F250 so a 4" lift on a 3500 is probably 6" or more difference to mine. As said, watch the weight ratings on the tires and wheels so you get ones that match your usage.
Other than that, it's going to handle a bit worse, brake worse, and probably ride worse so adjust your driving style. Lots of people tow with lifted trucks and do just fine, you probably will too.
Brian
Brian
44,068 PostsLatest Activity: Jun 10, 2026
