DirtyOil
Jan 11, 2015Explorer
DirtyOil wrote:
OP... I would suggest you try some of the GM/Chevy forums where you will get opinions from those that actually own/drive a similar truck and with a lift. The majority of "fuddy duds" that post here, without real experiences is redonkulous and dangerous.
I've towed with a 6" lift and 35" tires on the ole 2005 Ram CTD 3500, 8500lb TT to 23,000lb loaded goose neck, no issues!
Like I said check the GM/Chevy forums you'll get much better answers there then here!
I would like to see your setup hitched. 6 inch lift 35 inch tires on a 2013 Ram and you are able to tow level?
the 2013 does not have a lift... it was my 2005 3500 that had the lift.
Would like to ask those that say a lifted truck worsens the towing experience if this from first hand experience or just an uneducated guess ... at best?
Besides... the OP has a GM product.. and they could stand to have a few inches of lift... to get their frames off the ground! :B
44,068 PostsLatest Activity: Jun 09, 2026
