jerem0621
Jan 11, 2015Explorer II
DirtyOil wrote:No way I would lift a Tow Vehicle... No way.. I do not recommend it at all..Not at all. I highly recommend keeping it stock.
I see you tow with a mini van, don't see lift kits in any of the "stores" for mini vans... (this must make you an expert like most here?) although, I did see a early model ford Aerostar van with 4x4 and a lift. Kinda looked goofy but unique, it had the molded wheel flares and running boards...had the wheel offsets not been so drastic (tires looked like they were sticking out almost 4") it might have looked ok.
Don't know if they still have it their owners manual, but GM/Chev use to print that you had, to remove the bottom air dam on the front bumper if you were going to go four wheeling.(I guess it was to keep it from getting damaged) Another reason to lift a GM truck.
wow. :S
44,068 PostsLatest Activity: Jun 09, 2026
