TundraTango1312
Nov 07, 2014Explorer
elidodge wrote:
I love my ProPride, now that said there are 2 things to check. Tires on your tow vehical? Try right to left swap and see if the pull changes. second meke sure you are on a flat level surface an try to set your hitch square and lever. Good luck Bobby
I'm glad you like your ProPride...I wish I could say the same. My gut feeling tells me that the problem I'm having is being caused by the hitch...maybe even the weight distribution. However, I don't know for sure. I doubt rotating the tires on my TV will change anything since the pull has existed from day one, with all 3 tow vehicles and the TV does not pull when unhitched. I have adjusted the hitch on level ground, as evenly and square as possible. The hitch components are just not totally true and straight.
It would also be of great help, if someone who has a ProPride hitch could take some measurements and see if their hitch box is perfectly square and all other components are true, straight and lined up side to side.
