thomasmnile
Aug 11, 2013Explorer
ShaneThurman wrote:
My family and I went camping this weekend and my refrigerator would not get cold on electric. It is a Norcold refigerator. The freezer worked perfectly and I could get the refrigerator to get cold using gas. I checked the breakers and fuses. The on light also did not show any fault codes.
As posted, how is/was the weather where you camped? If hot and humid, yes the fridge section will struggle to cool and stay that way. If you haven't read the fridge owner's manual, take a few minutes to do so. Gas absorption refrigerators work, but not as well as a compressor type residential fridge. The freezer section chills first, the fridge section more slowly. The manufacturers of gas absorption units recommend the following tips to maintain cold fridge compartment temps:
1. Do not tightly pack the fridge. Air circulation around contents is important.
2. It is best to "pre-chill" the contents to be loaded into the fridge section.
3. If storing leftovers, they recommend letting hot foods cool down a little before placing them in the fridge. Norcold even recommends you consider food storage container type (round vs rectangular or square) because of the surface area to be chilled.
4. Especially in warm/hot weather, minimize the time and number of times you open either the fridge or freezer. When humid, you will likely notice frost or ice buildup on the fridge compartment cooling fins. If a heavy accumulation is present, it needs to be removed either by manual defrosting (no scraping the fins) or you can purchase a battery operated fan and place it on the top shelf of the fridge to move air around the fins. Also a good idea not to load the top shelf with containers that obstruct air flow around the fins. You can also search E-bay and buy an RV fridge fan that runs on the fridge's 12v. power. Inexpensive, and easy to install.
Also check the fridge and freezer doors for air loss around the door gaskets. The manual will tell you how to do this. Other things that may help: get a shaded/partially shaded campsite that keeps the fridge side of the trailer out of direct sunlight in the warmest portion of the day. If you don't have one, buy an infrared thermometer (pretty much available and inexpensive at HD, Lowe's Harbor Freight, etc). Useful to read refrigerator temps if you think there's a problem.
Good luck, hope this helps.
44,056 PostsLatest Activity: Jan 12, 2020
