retiredcamper20's avatar
Sep 21, 2015
quick connect hose for outdoor grill
I bought a Coleman Roadtrip LXE outdoor grill (2 burner) that has a regulator made to accept the 1 lb portable propane bottles. It works great. I went to propane store and had a 6ft hose made that connects to the built in quick connect on the trailer and then into the Coleman regulator in place of the 1 lb propane bottle. I get very little propane to come out and very low pressure and very low flame. Any ideas why? Are the portable grills made to only work with the 1 lb. portable bottle? And yes the quick connect valve is in the fully on position and all connections are screwed in tightly.
  • The connection on your trailer is already regulated. you need to remove the regulator from your grill to use it with the trailer supply.
