time2roll
Feb 08, 2021Nomad
Also consider a heated mattress pad to allow the furnace or other system to run at a bare minimum. Unless vented the catalytic heaters produce unwanted moisture too. Assuming you have power to plug in you can add heat pads to the water system to prevent freezing. www.ultraheat.com I added a water circulating pump to prevent freeze up.
