Kavoom
Feb 09, 2021Explorer
EsTC wrote:
After considering all of my options between trailer, sprinter van, etc., I determined that a TC works best for my purpose which is travelling to, and boondocking in, remote areas. Several areas that I am considering travelling to in the winter are in northern Canada where the temperature may reach 0 Fahrenheit. I must have working water system in these trips, which is doable with a propane furnace after some additions and modifications. I am open to buy any lightweight short bed camper such as Northern Lite 8-11SP, or Wolf Creek 850, or Lance 865.
The problem is that DW sleeps very lightly at nights and the propane furnace noise will be a deal breaker (or even non-starter) for her. I am looking for alternatives to propane furnace. I am open to replace the propane furnace with more than one appliance if needed, but the one or more appliance must heat the basement, camper, and water. What are my alternatives.
So far Alde system sounds like a good option. But I am unsure about how much and what kind of challenge should I expect if I want to replace a propane furnace with an Alde system.
Another good option is a Truma Combi. Again I am unsure about the challenges and complications I must expect. Although the first challenge is to find a Truma Combi.
Another option is to replace the propane furnace with an Aitronic D2 which will heat the camper and basement, and buy a separate water heater. Airtronic D2 is a fantastic heater, but this route requires buying two appliances and I am yet to find an efficient, lightweight, stand-alone water heater.
Yet another option is to heat the camper using Mr. Buddy, Plat Cat, or panel heaters and then use a few fans to push warm air into the basement. The problem here is I still need to find an efficient, lightweight, stand-alone water heater. Moreover, I am not sure whether pushing warm air with fans into the basement will keep water tanks from freezing in extreme cold that we will be in (I have considered adding thermostat-equipped light bulbs or small electric heaters or pads close to, or around, tanks, but found that unrealistic and prone to failure given the complexity of adding several of these and their electricity consumption).
If you have any idea about any of these or something different that may direct me to a solution I have not thought about, please share it with me. Thanks!
Florida comes to mind.
