rockhillmanor wrote:
X2
Really no need for a pump.
I just put the pink stuff in the fresh water tank and turn the pump on.
That pink stuff gets into EACH and EVERY crook and bend of your water lines. AND it goes thru/protects the water pump too.
Open every faucet until it runs pink and then close them. Then I take a gallon and pour into all p-traps. Takes all of 10 minutes!
And NO it does not leave any taste after you flush it out in spring. That is a mind over matter myth!:C
Only problem is with some water tanks, the pick-up is mounted on the side of the tank taking up to 10 gallons or more of pink stuff to do the job.
