campigloo wrote:
This has been a great read, but readily admitting being somewhat simple minded, I just don't see some of the advantages in having peak performance at very high rpm.
You bring up excellent points. The advantage of being able to turn higher RPMs is that you can use a lower gear, and all things being equal, lower gears put more torque to the wheels than do higher gears.
Diesel engines compensate for this by providing more torque at the crankshaft. But there are disadvantages to that. More torque means you need heavier-duty components, which means added cost and weight. On the other hand, it often means greater longevity.
campigloo wrote:
When I drive, I don't take off from a dead stop @4000 rpm.
I don't either, and this is where the diesel will excel. But in my truck, with my 4.17 1st gear, I'll be at 3500 RPM before I even cross the intersection. From there, I have all the power I need and more. With my trailer behind me, I can easily outpace the normal flow of traffic, even from a dead stop on an (upwards) incline.
I prefer gas for the simple reason that 95% of my driving is not towing. Gas engines are smoother, quieter, and cost a lot less. For towing, people make it sound like a gasser will be turning 5000 RPM all day every day. Not true at all. The vast majority of the time I'm ticking away at 2000 RPMs. On those occasions when I need additional power, it's only a downshift away, and I'd
much rather downshift than have to slow down due to lack of power. Pulling away from a stop it will wind up more for sure, but that's such a small fraction of a typical towing trip it doesn't bother me in the slightest.
-- Rob
