Walaby wrote:
Good luck. Think most of our response was in response to your original post where you said you wanted to be able to maybe tow 4-5K and also use it as a replacement when your 350 wasn't available. That need (as originally stated) and this need are totally different.
Mike
Fair enough. What I was asked was, is the rating 7000 or 4000. Since then it's clear the rating is the higher of what I'd seen talked about, which raised the original question. I just wanted to make sure that if we needed to haul 6 or 7000# with DW driving and me using the 350 ahead of her towing our TT, it could be done.
I got the truck yesterday for an overnight. The ride seems okay, a bit rougher than the F150 I drove, but okay. Noisier on our rough road than the 150 but the mpg is nice, 23+ for around 125 miles. Since most of that was up hill, from 6000' to 9500 at Wilkerson Pass, it will improve when I return it to the dealer, as that will be down hill.
My biggest complaint are those hideous side mirrors. They make it through the garage door with just an inch or so on each side. With all the goofy gadgetry you'd think Ram would have had electric collapsing standard.
