brulaz wrote:
I dunno. Would bet the fairly low HP of the EcoD is the culprit.
But I agree with Don, who cares? It's only a minute or so, and if mileage is important to you and you are within it's GVWR and GCWR, the RAM EcoD is a great choice.
I didn't mention the time. Personally, I looked at the horrible slow down (speed) the truck encountered and watched how miserable the two testers were driving it!!!
So many on this very site complain and comment about power and "more truck", well this is definitely not "more truck". There are V6 gassers that blow this truck away up the same grade. This motor puts MPG ahead of all else, and if passing and up hill power is not priority to the driver...well then this is a viable option.
Also take note, the throttle was floored the whole time and RPM's generally high for a diesel. Two key points that people don't seem to care for while towing, as they perceive and assume this as straining the motor. You don't want to floor it or allow high RPM, and this will make matters even worse while towing.
It all comes down to what the driver is willing to tolerate and what their top priorities are while towing. If power isn't on top but MPG is, this is the right truck and motor combo.
