Hybridhunter
May 23, 2014Explorer
Good / analytical review
Engine comments from above...
All this number crunching is well and good, but the real test is out on the road, where the diesel showed its true colours. Frankly, it felt downright slower than the Pentastar V6, which took off in a lively fashion, both unloaded as they were. Unfortunately, this introduction to the 2014 Ram lineup did not include a towing test for the light duty diesel or the gas V6, and only a brief loop around a circuit of cones in the parking lot for the Hemi-equipped V8 with a rather large power boat hooked up to the hitch.
First Drive: 2014 Ram 1500 EcoDiesel trucks ram first drives ?First Drive: 2014 Ram 1500 EcoDiesel trucks ram first drives ?First Drive: 2014 Ram 1500 EcoDiesel trucks ram first drives
2014 Ram 1500 EcoDiesel. Click image to enlarge
Both the 1500 EcoDiesel we drove in Laramie Crew Cab 4×4 trim ($64,085 as tested) and V6 Pentastar in Outdoorsman Quad Cab 4×4 trim ($44,760 as tested) were equipped with the air suspension and novel five-link rear coil suspension (instead of leaf springs, but not fully independent). However, the gas V6 felt positively sporty in its ride quotient compared to the diesel. Despite being shod with wider tires (both 20-inch tire packages), the EcoDiesel felt soft, cushy, and a bit more tippy in corners – the engineers we spoke to ascribed the marked contrast to that engine weight difference. Unlike Chevy and Ford offerings, Ram’s air suspension can serve as both an off-road duty tool and can lower and adjust for ideal cruising or towing, so they do not have custom suspension packages for those specific tasks.
After driving both the gas and diesel V6s back to back in the morning, I came back to spend some more quality time in the diesel in the afternoon. From inside the cabin, it is as quiet as any modern car, even at typical high-speed cruising speed on the 400-series highways. It might not feel as quick, but it builds up steam confidently and evenly, and cruises with effortless quiet on the highway. At a steady 120 km/h, it was ticking over at a low 1,800 rpm, the diesel rasping away faintly in the background.
As mentioned, the diesel seemed a bit soft in the corners compared to the base V6, but not a cause of concern. Steering is light and fairly slow, preferred for the type of work these vehicles are put to use, but still feels safe and surefooted on the highway at highway speeds.
