jus2shy wrote:
Perrysburg Dodgeboy wrote:
BTW the eco diesel does have two filters, one is a water separater and the other is a fuel filter. I have the 2014 Ram book in front of me and that is what they have listed.
Don
Hi Don,
I took a second look at page 105 to 109, and there's only mention of the chassis filter. No mention of an engine mounted filter. Did you by chance read the HD section which is further down the book? Because the Cummins has 2 filters but I can only find 1 for the 1500 section.
I know that for the HD truck, both fuel filters are also water separators. They are both filter-in-a-filter designs. So when you do your monthly draining, you have to do the rear filter housing and the engine filter housing on my truck.
Nope looking at it right now. This is the book you get from the dealer. It reads as fallows under the 3.0 ECODIESEL V6 240HP 420TQ "Clean by design - An Invaluable Dual-Filtration System. Fuel sources vary in quality; climates across the continent are like night and day. The 3.0L EcoDiesel utilzes dual-filtration technology for greater protection against contamination, reduced injector corrosion and enhanced durability".
Don
