dodge guy wrote:
Grit dog wrote:
IdaD wrote:
Grit dog wrote:
To reiterate the question in more simple terms, how handily will a 3.92 geared Hemi blow the doors off a 3.21 geared Hemi?
Apparently...it won't.
Wow!
To say I’m surprised would be an understatement!
Thank you for that!
Can’t imagine the tires making that much difference. They must just work as good with the higher gears!
That’s because the 3.92 truck had larger diameter tires. So in the end the ratios were very close.
They say they a jump is worth a hundred horsepower. That and smaller take-off (pun intended) tires should make the 3.92 the winner every time.
