davisenvy wrote:
I have a payload of 1200 lbs and max towing of 7,800. Hemi V8, stock class IV hitch, not sure about the trans cooler. I will have to add trailer brakes to the truck though.
Bottom line is that with a measly payload of only 1200lbs, you're going to be very limited, ESPECIALLY for a toyhauler.
Second, having a hitch RECEIVER doesn't mean it has the factory tow package, which would include a trans cooler and pre-wiring for a brake controller.
Forget the Max towing number, with a payload of 1200lbs, you'd never even get close to 7800lbs.
Lastly, using fictional website/brochure dry weight numbers is a common newbie mistake. NO RV weighs that near those numbers, especially when loaded. With a bogus tongue weight of 670lbs, it could easily weigh 1000lbs with the toy and stuff in the trailer. Subtract 100lbs for the WDH, that leaves you 100lbs for the driver, passengers and stuff in the truck.
