Gdetrailer wrote:
DirtyOil wrote:
On the new to me 05 Ram 2500 CTD, I note a big difference in lighting compared to Old Faithful (97 Ram), but it's still not perfect. What type of bulb should I use while staying street legal? I've used Sylvania's zXe in the old truck, they are good but pricey. What about SylverStar Ultra?
rather then replacing bulbs try what I did to my 05 ... huge difference even with OEM bulbs. I tried the different aftermarket bulbs, they were just as bad. Then I changed the headlight wiring harnesses to heavier gauge wire(the light gauge wiring is ok for relays, but not for headlights)... check this out:
http://www.danielsternlighting.com/tech/relays/relays.html
We have a winner!
Folks please read the link.. It IS what I am talking about.
It isn't your bulbs, nor is it your reflector or housing it IS THE WIRE.
All it takes is two Bosch style relays, some wire and now days you can buy plugs and sockets and you now have the light you are supposed to have.
Replace the housings, first.
Use ANCOR wiring products, HELLA relays and Phillips Night Guide lamps. I've done the Stern conversion on four vehicles the past dozen years.
