ib516
Jul 31, 2018Explorer II
jmtandem wrote:So we, the audience, cannot point out errors in an articles if the auther is "super excited" about what he is writing about? I am pretty sure he would give constructive criticism and correct another writer if they posted wrong info about a gun or wrong RV specs.
For somebody that made the first comments on the original article and pointed out all the mistakes in calculating percentages and fuel usage, you tend to be a little thin skinned when folks make other comments or observations; none of which says you are or were wrong.
Again, 4700 pounds of trailer is nothing for either engine. Had the OP been towing 12,000 pounds of fifth wheel I am sure the difference between his 6.4 engine and a new diesel would have been dramatically different and would only have supported your position more.
I pulled a 12k 5er with a 5.9L Cummins in a 2007 3500 SRW and then the same 5er with a 2014 Ram 2500 with the 6.4L Hemi. The Cummins got 10-12 mpg and the 6.4L Hemi got 7-9 mpg with the same load.
44,056 PostsLatest Activity: May 04, 2014
