Road_Phantom
Jun 21, 2019Explorer
ram 2500 and 3500
What is the actual difference between the Ram 2500 and 3500 single wheel pickups besides leaf springs and coil. Are the bearings and brakes the same if both have 18 inch rims?
mich800 wrote:Me Again wrote:
If you owned a 3500 SRW would you agree with me? People seem biased to what they own. I have seen way to many on this and other forums that bought a 250/2500 and then a larger trailer in a year or two, and back they went to the truck dealer.
:h and how muck in depreciation did they pay for the new sticker. :B
JIMNLIN wrote:
Actually the smaller rear axle diameter goes in the gas version F250 and the 250/350 srw diesel as always gets the larger rear axle diameter. The 6.7 diesel has lots more twist vs the gas = higher truck GCW numbers which are the same for the 6.7 diesel in both trucks.
Axle diameter doesn't carry weight on a full floater rear end anywayz...just the axle tubes.
The F250 with the camper package or heavy service package comes with the same front and rear suspension as the F350 srw.
Those that are looking at F350 SRW keep in mind they comes in several gvwr numbers from 10000 lbs on up to 11500 lbs and have three different rawr packages.
Gotta' agree with 4X4ord on the F350 srw. IMO the 250/2500 trucks are the most under rated LDT on the road.
Me Again wrote:4x4ord wrote:
I think offering a srw 1 ton is silly. The 2500 should be sprung to carry what single wheels can carry and there is no need for a srw 3500.
You have a backwards, why have a lower rated 250/2500. If someone wants a grocery getter, then get the 150/1500.
