Groover
Jun 16, 2021Explorer II
4x4ord wrote:Bionic Man wrote:
If the standard output Cummins was able to maintain speed, wouldn't it be reasonable to assume that the HO Cummins would use a similar amount of fuel, as it would not need to make more power to do the same speed?
Honestly I'm surprised these trucks are able to do those speeds up the hill. My 350/800 Cummins won't pull my 12,000 pound 5er eastbound to the tunnel at the speed limit. I'm somewhere between 35-40 MPH at the very top. My best friend's 2013 PSD pulling a very similar trailer is the exact same. Does the higher profile of the RV really make that much of a difference?
At 40 mph the added wind drag that might be on a 12000 lb high profile fiver is negligible compared to a 12000 lb equipment trailer. At 75 mph the difference in drag might be a factor. When you’re foot to the floor doing 35 - 40 mph your using all the power your engine can make and yet the power required to overcome drag at that speed is going to fall between 30 and 40 hp no matter what kind of trailer your pulling.
That does seem to be awfully slow. I went through the pass a few years ago in my motorhome equipped with 300/600 detuned Cummins and running about 28,000lbs GCWR. I may not have been doing the speed limit but I don't remember being particularly slow either.
