js9234
Dec 13, 2019Explorer
I wouldn't listen to that so called "technician". He sounds very uneducated on the modern cummins. He probably owns a first gen and is just talking ****. A majority of the stuff he said is nonsense.
hvac wrote:
For many emission components, the expected service life is 100k miles. Many are not even warranted past 36k miles. A modern diesel has huge financial exposure past 100k miles. Go to the turbo diesel forum.its getting to make sense to turn them at 125k miles or less.
The following is a brief comeback from one of lead moderators, I asked if my new 2018 CTD would be reliable past 100k miles. He's a technician as well,
Ever had to replace the complete exhaust\catalyst system when a DEF injector sticks just destroys some $4k of emissions stuff plus itself? Do that ONCE then look at the bottom line on costs. What are you gonna do when the ignition module fails and it won't recognize that playschool key anymore? Just TRY to jump that truck into running to where you can get it fixed cuz you ain't doing it yourself anymore due to the fact it REQUIRES dealer programming to install and set it up. Don't ever do any one a favor jumping their dead vehicle in a parking lot, ANY little inattention or unknown problem will take out a TIPM or ECM and you are in the same boat. Do I dare mention turbos that carbon up, head gaskets that leak for no obvious reason, injector tips that break off, injectors that hang and melt pistons on a hard pull, and the infamous grid heater bolt that burns off and gets sucked into a cylinder
