samhain7's avatar
samhain7
Ram 2500 DEF fluid
Hi all
I am on tank of gas # 6 on my new to me truck and thrnDEF fluid gage has barely even moved
How long do you get on a tank of DEF fluid and how big is the reservoir?
Thanks
  • In theory, you should need DEF about the same time you need an oil change. But there are a LOT of variables to that.
    Your DEF gauge is probably working just fine. You shouldn't need to fill after 6 tanks of fuel. According to Cummins, DEF consumption is 3% - 5% of your total fuel consumption.
    The DEF tank on a 2016 2500 is 5.5 gallons.
  • The DEF gauge isn't linear. It will show full until its about half a tank, then it will quickly drop down towards empty. One day you will get a warning that DEF is low, that is usually when I fill up. If you don't fill up then, you'll eventually start getting messages saying 250 miles to shutdown, etc.
    During the summer we take shorter trips, so I just dump 2.5 gallon jugs in when I get the low DEF warning. In the winter we take a long trip, so I usually fill the DEF at a pump, so I can fill the tank.
  • samhain7 wrote:
    Hi all
    Thanks
    Your problem is you have been putting "GAS" in your Diesel Truck.
  • Your gas truck will run forever without filling the DEF tank. :W
    The answer to your question is in the owners manual.
  • It varies. You will use more when towing than when not towing. It also makes a difference in how big the DEF tank is. My understanding is to expect around 1000 miles for each gallon of DEF when not towing.
