ib516 wrote:
wanderingaimlessly wrote:
Yeah , it's sad, but the coil suspension makes that light riding truck, have very little payload after you allow for the diesels weight.
Sorry my friend, but that is 100% BS.
The 2380# payload is typical for the 2500 crew cab diesel class and has zero to do with the rear springs, and everything to do with the 10k weight limit for class 2 trucks (that is until GM changed the rules sort of, but that's another topic).
All that means is your truck weighs 10,000 - 2380 = 7620# empty as it sits.
The coil spring rear suspension gives a better ride, empty or loaded, but does not reduce the available payload. Trains engines ride on coil springs, and I think they're pretty heavy.
And I simply said it was a light payload cap. And advised how to check it.
The Manufacturers guidelines show the light payload. I did point out that tow capacity was more than sufficient especially since it is the same engine as the 3500 series.
If you want to overload yours, go ahead, but acknowledge that you do this by your own decision and thought process, and at some point some agency or lawyer will prosecute/sue someone for violating the guidelines and going over the 10,000 limit you point out.
What the rear axle in and of itself can carry wont be the determining factor.
And whether or not a train engine has leaf or coil springs has nothing to do with springs spec'ed out to give that soft ride at a 10,000 weight limit in this pickup.
