Need Help or INF. I bought Used 2008 Ram 2500 turbo Diesel 6.7 Big Horn, Very low Mi. Runs And Looks great, But the first time I had to change the oil,12 Qts, w/new filter, On checking the level to ma...
Very normal. I usually let my engines drain overnight when doing oil changes. Even then the 6.7 leaves at least 1/3 quart in the pan. So when adding new oil add about 11 2/3 quarts end you will be on the full mark. Mine was always black as soon as I started the engine. Now the 15 is a completely different animal. They oil is still not black at 2,500 miles.
