evanvalk
May 27, 2015Explorer
RAM 2500 Oil.
Need Help or INF. I bought Used 2008 Ram 2500 turbo Diesel 6.7 Big Horn, Very low Mi. Runs And Looks great, But the first time I had to change the oil,12 Qts, w/new filter, On checking the level to ma...
DirtyOil wrote:Well I don't know fellas. I own a 2001 Ford F250 Power Stroke 7.3 I change the oil every 2500 miles. Once changed I can read through it for over 1000 miles. After reading all these posts about black oil I had to go out and check mine just had it changed 600 miles ago still looks like it just came out of the bottle. Clear and clean. OK little smokey but still very clean. So how long are you guys going before you change your oil? Oh one more thing--- It never even leaves the garage less it has some sort of trailer attached to it so it's a work horse for sure
Two entirely different beasts, 7.3 Power Stroke and the CTD, Cummins uses multi injection events, pre, main and third. Third injection is just after main combustion injection, small amount of fuel is injected to aid in reducing exhaust emissions, the result is some of the soot from the last injection event ends up in the oil making it black. Will have no lasting effect on the engine as long as oil changes are done at correct intervals, as you would do for any engine, to make em last.
