GordonThree wrote:
Temp "gauge" is in the middle of the dial ... Will try to remember to check the digital readout in the menus next time I'm behind the wheel. no CEL or messages waiting from the computer
So bee more specific. Check the actual coolant temp and describe the conditions in which it takes a while to get warm....I.E., it's been -20deg up there.
Truck outside?
Plugged in block heater?
Was it fine last month when not so cold?
Once you can check all those boxes, start looking for a problem if everything else is as it should be.
