thehippie
Oct 20, 2015Explorer
Ram 2500
Why is the Ram 2500 crewcab longbed with 6.7 Cummins, even though it's only 6 cylinders has more towing power than the similarly equipped Ford F250 powerstroke diesel, the same displacement at 6.7 bu...
rhagfo wrote:Turtle n Peeps wrote:thehippie wrote:Turtle n Peeps wrote:i thought inline vas more torque than V.
It doesn't.
Where are your numbers coming from?
Nope, torque is not power. Never has been and never will be.
To give you an example: On a bike I can put out around 225 Ft/lbs of torque. If I had a 5 foot crank I could put out more torque than a new Cummins 6.7 engine at the crank!
I can put out only about a 1/2 a HP for a short period of time.
Even though I can put out a lot of torque I would not make a good TV engine!
That is why a Diesel with less HP than a gasser can pull a lot more weight.
