FireGuard's avatar
FireGuard
Explorer II
Feb 21, 2020
Ram 3500 DRW 6.4 8sp for TC?
Doing my research for a new TC hauler, I spent some time on Ram forum researching the new Hemi with 8 speed with positive results.
Everyone who has the new 8 speed is very happy with the performance and the 3:73 vs 4:10 doesn’t seem to be as critical with the additional gears.
For a 5k lb TC I would be looking at a 19-20 Ram 3500 CC DRW 4x4 6.4 8 speed 4:10.
I like the new Ford 7.3 but my last 3 trucks have been Ram and I’m happy with them.
A new Tradesman can be bought for low $40K range. I haven’t seen any Fords but I’m sure they will be significantly more expensive.
My use would be carrying the TC and occasionally towing a 4K lb Jeep Wrangler.
Based on recent tests, the Ford may offer a little better performance but I think the Ram will be plenty of truck for my needs.
Anyone running the new Ram Hemi 8 speed and what are your thoughts.
  • 92k miles on my 6.4 SRW hauling a 2,400# Lance 815. Have the 3.73 gears and it does a great job. Usually don't have to use tow/haul so have 6th gear.
    Occasionally I've hauled ~4,500 car hauler behind it and do use tow/haul then which locks out 6th gear and it still does pretty good.
    Looking at upgrading and next time I will order the 4.10s as with the 3.73s I have to run a few mph more than I would like to get the rpm a bit higher. Think my mpg would be a hair better as the slower speed and less boggin of the engine would make up for the lower gears. I would definitely go with 4.10s if we go heavy enough to require a DRW.
    It's no diesel as I had a 2004 5.9 exact same configuration before, but I have never regretted my decision to go with the 6.4.
  • I don't own one either but with the new gas engine and trans combos I wouldn't even consider a new diesel. Partially due for my dislike for DEF.
    I think there are a lot of folks that are going to be buying gas instead of diesel.
    I read in the truck section of this forum that a few people picked up new 2020 F-350s with the 7.3L for around $44K. I think they were base XL packages.
  • I can't offer any insight in terms of the 6.4 because I don't own one, but my only concern with a Ram 3500 dually with the gas engine would be resale value. There is likely a very, very small market for such a truck, and I'd think about that before I bought it. If you think you might not have it a long time, I'd get the diesel just so you can re-sell it if you want.
  • “my last 3 trucks have been Ram and I’m happy with them.“
    Haven’t you already decided on a RAM?
