Has anyone replaced the factory 235/80R17 with 255/80R17? It looks like they are 1.2" taller and .7" wider. If so do you have plenty of space between the rear wheels?
You have to maintain the proper distance between the Duals to prevent sidewalls from touching, which is BAD. Some add bigger tires by adding a spacer between the wheels. I think I'll keep my OEM size.
