ShinerBock wrote:
4x4ord wrote:
Are you sure it is coming out of 4wd? Jack up one front wheel and see if it spins freely. Should Ram front hubs free wheel when in 2wd? (ie Does Ram use a auto lock hub like Ford or a constant locked hub like GM?)
Ram's 4wd system disengages the front axle completely when not in use unlike the Ford system which keeps the front axle spinning at all times, but locks the hubs when power to the wheels is needed.
The Ford transfer case does not transmit power in 2wd but the hubs Auto unlock as well. So with the Ford you can manually lock the hubs but you are still in 2wd until you shift the transfer case to 4 hi or 4 low. Chevy does not have hubs that disengage … the front axle and diff rotate in 2 wheel as well as 4 wheel drive? I think Ram is like Chevy but I don’t know?
