buc1980 wrote:
I wish that Ford have a better transmision to keep the load under control going downhill.My 2011 F350 need brake to slow it down and keep the RPM under control.The Ford engeniring supose to do a better job in that matter.
Not sure either, RE serious or trolling????
I've also got the 2011 F350 and it certainly works fine controlling loads going downhill.
One thing you must realize is that the Ford works best when starting down at a speed in the 50 to 55 MPH range max. Starting downhill at speeds greater than that just means you will need to use your brakes.
I've gone down Lookout Pass in Idaho/Montana border and Homestake Pass at Butte Mt without touching the brakes, just started down at slower speed and stayed that way.
