The following quote caught my eye:
The Mad Norsky wrote:
"One thing you must realize is that the Ford works best when starting down at a speed in the 50 to 55 MPH range max. Starting downhill at speeds greater than that just means you will need to use your brakes."
I don't think the Ford is unique from any of the competition on this count. All vehicles work best when starting down hill in a lower speed. Physics dictates that the Ford is no different than a Volkswagon in that regard.
Starting down a hill slow and in low gear helps save the brakes regardless of vehicle brand or transmission type... whether with stick shift or with fancy electronic shift strategies.
