MTPockets1 wrote:
ib516 wrote:
2013 F450 (4 door cab, diesel, 4x4, 8' box):
- max payload capacity of 4,969 pounds (diesel)
- max conventional towing 18,500 pounds
- max 5th wheel towing 24,700 pounds
- 14,000 pounds GVWR
- max GCWR 33,000 pounds (4.30 axle)
2013 RAM 3500 (crew cab, diesel, 4x4, 8' box)
- max payload capacity 5,800 pounds
- max conventional towing 17,000 pounds
- max 5th wheel towing 29,130 pounds
- max GCWR 37,500 pounds (4.10 axle)
Max Payload for the F450 Crew Cab 172.4" Wheel base is 7080 lbs.... per www.ford.com/trucks/superduty/specifications/towing/
5680 lbs max payload for the 3500 Ram ...... Other specs look right
There's no way the F450 pickup has a 7080lb payload. 14,000 GVWR - 7080lb payload = empty truck weight of 6920lbs. No way that truck is that light. More like 8500lbs or more empty.
