MTPockets1 wrote:
ib516 wrote:
2013 F450 (4 door cab, diesel, 4x4, 8' box):
- max payload capacity of 4,969 pounds (diesel)
- max conventional towing 18,500 pounds
- max 5th wheel towing 24,700 pounds
- 14,000 pounds GVWR
- max GCWR 33,000 pounds (4.30 axle)
2013 RAM 3500 (crew cab, diesel, 4x4, 8' box)
- max payload capacity 5,800 pounds
- max conventional towing 17,000 pounds
- max 5th wheel towing 29,130 pounds
- max GCWR 37,500 pounds (4.10 axle)
Max Payload for the F450 Crew Cab 172.4" Wheel base is 7080 lbs.... per www.ford.com/trucks/superduty/specifications/towing/
5680 lbs max payload for the 3500 Ram ...... Other specs look right
Those numbers are right off of each manufacturers website.  I wasn't quoting
MAX payload numbers, I was quoting them both
as equipped for the test.  As you see, I was talking about a 4 door cab, 4x4, 8' bed, etc. for the F450.  According to Ford, an F450 equipped like that has the payload number I typed above.
If I was quoting max numbers, the RAM 3500 max tow rating (for example) is over 30,000#.  This truck as equipped is only :W 29,130#
