ShinerBock
Mar 10, 2020Explorer
2001400ex wrote:FishOnOne wrote:
It doesn’t matter if one brand fills differently from another brand. What’s important is the fill method is consistent from the initial fill to the second fill to calculate fuel mileage and I will say the method used in this test is good.
Also I’ll second what John Deere farmer has stated that the new Power Strokes are making better fuel economy and people are noticing it.
It's not the best test with diesel because it foams so much. If the tank is lower the first time, it'll foam more than when they fill with this method. Watch the half ton diesel test. One of them he actually says "wow that was a long second pull". Meaning they aren't consistent.
I have had this happen in my diesel trucks and cars on more than one occasion. It happens a lot on my current car because it has a smaller filler neck. If I don't have the nozzle in just right, it will foam up really quickly.
I can tell when it happens because I input my mileage in an app. I generally get about 45 mpg in my car since I only use it to do the same 80 mile loop everyday. If my app shows that my mileage is considerably less than 45 mpg, then I know it is not correct. One time it clicked way too soon so I waited for ten seconds to fill it up some more as usual. It clicked really quickly the second time as well. So before I put the nozzle back on the pump, I inputted the numbers in my app and it showed 41 mpg which I knew was wrong. I adjusted the nozzle and was about to get almost another two gallons more fuel in there bringing my mpg up to 45.
Some nozzles are finicky like that and different pressures in different temps seem to effect some more than others. It has happened a handful of times in my truck, but not nearly as many times as my car.
