1Sludge1
May 17, 2022Explorer
Ram 5500 with Flatbed and Torklift Super Hitch question
First some background:
I have a 2022 Ram 5500 60" ca chassis cab that I am trying to set up with a flatbed and Torklift Super Hitch. Unfortunately, it has been a bit of a struggle to get this done.
The first challenge was finding a flatbed that didn't already have a hitch built into the bed while also having a short enough rear skirt so that it would not interfere with the Torklift Super Hitch. I want the Torklift Super Hitch so that I can run a hitch extension and pull a boat and trailer with a camper on the flatbed.
I found a flatbed that I like that looks like it will work with the Super Hitch, but unfortunately, the upfitter says they will not install the Super Hitch. They have issues with using the same truck chassis bolt holes for their flatbed shear plates that the Super Hitch also uses. So they will install the flatbed, but I will have to install the Super Hitch afterwards.
The second challenge has been with the actual install of the Super Hitch. The flatbed upfitters use larger bolts for their shear plate mounts versus what Torklift uses, so I have to have the Super Hitch side plate holes enlarged. Also, the Super Hitch side plate has a mounting hole that doesn't line up with the truck chassis hole, so I will have to have the side plate modified for that.
I know this has been done by others out there, but I haven't been able to talk to anyone that has done this to see what their experience has been.
So finally my question. If you have done something similar with a flatbed and Super Hitch, can you post what truck and flatbed you have and who your upfitter was? If you have any details to add or pictures of how your flatbed and Super Hitch were mounted, it would be greatly appreciated.
