Cummins12V98 wrote:
transferred wrote:
Cummins12V98 wrote:
So the reality is the 2500 and 3500 SRW trucks have only 500# RAWR separating them when properly equipped?
The reality is the 3500 SRW is rated to carry c.1,500 lbs more weight making it the correct choice over the 2500 everyday of the week and twice on a Sunday. :)
Did you read the two charts on the last page I posted with the rear axle weights shown to be 6K on the 2500 and 7K on the 3500 SRW's?
My math shows 1,000# difference. Where do you come up with 1,500#?
I'm sure he's basing it on payload rating, although on the 2500s that figure is restricted due to the truck class max 10k GVWR. It's simply an on-paper restriction that matters to some and doesn't matter to others.
And again, in most cases the RAWR on the 2500 is 6500 lbs, not 6000 lbs, which makes for a 500 lb difference.
