Me Again wrote:
IdaD wrote:
That's a neat story about coil springs on a 60 year old truck. Should we compare a 60 year old phone to my iPhone next?
The payload rating on a 3/4 diesel is simply a function of the 10k lb GVWR class limitation. The 1000 lb lighter 6.4 2500 payload rating is accordingly 1000 lbs higher, and it has the same rear coils. Bottom line between a 2500 and SRW 3500 is you're splitting hairs in terms of capability and daily driving ease of use. Move to a DRW and now there's a real distinction on both fronts.
Put the same large truck camper on the two and see if you think they are similar.
Without going to air suspension, it is hard to soften ride and still be able to carry heavy loads.
RAM made a decision to differentiate between the 2500 and 3500 SRW when they but coils on the 2500. FORD and GM have not yet gone that direction.
Chris
I never said they were the same, just that the difference is pretty minor. If you do a search ib516 actually ran a back to back test with his 2500 and a buddy's leaf sprung 3500 (both 2014s) using a fifth wheel with around 3000 lbs of pin weight. The coils sagged .7" more, although because it rides a bit higher unloaded, the loaded difference between the two was a bit under half an inch. Huge difference, right?
