stevemorris
Oct 05, 2017Explorer II
Ram 6 vs 8 speed
all else being equal, engine, rear end ratio, what's the difference between the 6 speed and 8 speed offered by Ram as far as towing is concerned
VernDiesel wrote:
Page 1 of this thread Wilbur1 asked why don't they offer the eight speed with the 6.4 2500.
Useing the the Ram reps comments in the link above was to answer the question posed & being bantered in this thread. At least that was my understanding. I didn't copy paste and read the link. I suppose the question there was more general as in with Duallys and using the Cummins.
VernDiesel wrote:
The stupid part of the Ram reps comments is that the 2500 gas HD isn't rated to tow 30k or carry 7K either. At least he got the part right about the eight speed not being able to hold greater weights in Park on a hill without the risk of it breaking & rolling down the hill.
FishOnOne wrote:
The ZF 8 speed is going to be much more reliable than the 6 speed and if much more efficient.
Grit dog wrote:smurfs_of_war wrote:
8 speed was the nicest towing transmission I have ever had in a half ton. Always knew what gear it needed and when you dropped gears going down a grade it stuck like a magnet with basically no input of the brake pedal. I had 3.92s in it.
As for it's absence in the HD line up- it has been covered in depth on a few forums. It has to do with the ability of the transmission not being rated to hold the full GVWR of the truck when parked- so i assume the pawl or something was the weak point?
Which is so weird because that same basic 8 speed with heavier internals is backing 700hp cars. I have to believe it would stand up behind the 6.4 Hemi no problem.
