Grit dog wrote:
ScottG wrote:
I think the fluid is very expensive but yes, unless you want to do it yourself, let them do it.
Could be worse, my SRT is coming up for the same service and it's pushing $1K.
$1k? That’s nuts. I believe your SRT is newer, 8 speed? But I just paid for my first trans service in a long time on the wife’s SRT. It was 2 hundred and something. Local trans shop that does good work.
Yes, it's the 8 speed. Killer trans!
They could not have done it to spec because it requires the integral pan/filter be replaced and it's something like $400. Then the correct fluid is pricey as well and the refill procedure takes a lot of time.
