TxGearhead wrote:
Yeah my 2016 has the yellow Mobil 3309 sticker.
Guess I'm missing something about the oil cooler lines.
If you read the diesel supplement maintenance schedule it says "Drain the transmission oil" which means remove the plug and drain then refill. At 60K it says replace filter which would require dropping the pan and refilling.
IF they are including a flush which will replace most of the torque converter and cooler oil it will most likely require the removal of one of the cooler lines for the connection of flush equipment. Maybe the dealer has a new trick which lets them flush the cooler and converter without using a line but I've never seen it mentioned. So, are they really going to flush it or are they going to just drop it and refill?
