Dayle1
Sep 15, 2016Explorer II
In my opinion the Sidewinder is the best option. Some slider hitches are too wide to work with the narrow Rambox. The Sidewinder is automatic and has several benefits over any other potential solution. Hookup at sharp angles, backside of the pin box cannot hit the truck sides, turning response when backing up will be faster and the fiver will not cut inside the truck rear tires as bad when turning a corner. Routine maintenance will probably be less than with an auto slider.
44,068 PostsLatest Activity: Jun 01, 2026
