Cummins12V98
Mar 17, 2023Explorer III
Grit dog wrote:Cummins12V98 wrote:dodge guy wrote:
I work at a dealer an I’ve only seen one Aisin failure. I see far more emmisions failures than anything, DPF, sensors, etc!
Before I bought the MH I was looking for a 6.4 gas truck specifically to get away from an issue while on the road.
You are SPOT ON!!! I personally know a Top Mechanic and the Parts Manager at my local Dealer, they say the same.
So YOU had the only Aisin failure in your dealers history? Lol
Very ironic…
Never said that, you need to keep track of my posts like "FISH" does. I did say they had two I believe. They replaced both trans no question as they had bad castings causing internal bleeding if I remember correctly.
Truth!!!!!! Is my trans did NOT fail from any issue with the trans. Mechanic did not follow proper seperation and assembly to replace weeping gasket. So again you need to keep files of what I have said like "FISH" does. :B
