Cummins12V98
Mar 22, 2023Explorer III
I just replaced my front brakes and rotors with EBC. While tire was attached and off the ground I did the push pull top bottom and sides with ZERO slop at 102k.
Why did I replace brakes at 102k??? Because I had a drivers side sticking caliper and inside pad ground into the rotor. So I replaced with OE caliper.
I also removed my ABS sensor and pumped AMZ/OIL grease into the hub assembly. Will be interesting if the hub assembly lasts a long time or not.
