wilber1
Apr 02, 2015Explorer
ShinerBock wrote:wilber1 wrote:
Do you honestly believe th 3.5 EB got 11.3 MPG on that tow test? Yes or no.
Do you honestly believe a gas engine is only limited to a 14.7:1 AFR?
Well, at least I will answer your question. No, not exactly 14.7 but a narrow range around it. If you don't believe a diesel can use a large amount of boost for engine cooling and a gasser can't because its boost is limited due to it being directly related to power output, try ramping the EB's boost up to 23 PSI and see what happens. After all, "it is built like a diesel".
44,072 PostsLatest Activity: Aug 30, 2026
