FishOnOne
Apr 05, 2023Nomad
Golden_HVAC wrote:FishOnOne wrote:
Without detailed specifics, RAM is essentially saying all your EV truck concerns (Specific shot at the F150 Lightning) will be a non issue with their EV truck. This truck maybe so good it's forcing Ford's hand to redesign their Lightning already.
It takes Ford 5 years to go from a design to produce the tooling to install that tooling in a factory to actual production of a new vehicle. So if the 2025 F-150 EV is coming out in September of 2024, then 5 year before (September of 2019) is when Ford decided what it will look like and started to change the design from a computer drawing into the tooling they need to produce the truck.
By January of 2021, Ford knew what the 2025 F-150 looks like and has the tool and die makers producing that stuff. Ford could make a minor change, such as changing from a 130 to a 150 KW battery pack at this point, but by the spring of 2024, it will be to late to make such a change. And they want something new to put into the 2026 model refresh, so they might not want to start out with a 150 KW battery option until the 2026 model year update.
Ram is making a ridiculous 190 and optional 230 KW battery pack. By using 8 bolt rims, it seems to have a over 8,500 GVWR, so the highest of all the Big 3 at this point. Towing a fifth wheel is actually going to be possible. With the battery cell cost of about $150 per KW, that is about $15,000 for the 100 KW battery pack, twice as much for this size truck, no wonder they will not give out the total price! Maybe RAM is hoping that the price of batteries will drop below $100 per KW by 2025.
People towing with a Rivian and Lightning are getting about 1/2 of the rated mileage when not towing. So the 500 mile range, if they actually reach that, expect about 200 - 250 miles while towing a travel trailer that is lower profile, and a little less in a fifth wheel that is taller and more wind! That is still acceptable, as your can charge it very quickly because it is 800 volt battery, and can get about 200 amps X 800 volts or 160 KW into the battery - so a 30 - 45 minute charge will fill it a lot.
I think that most cars are currently limited to 400 volts from the charger, and the power cord is limited to only about 300 amps maximum.
The RAM has some great specs. I just wish they had come up with the design before 2020. And could have it in production by the end of 2023. But as the superbowl ad says "We do not want premature electrification".
I also think Ford thought the EV F-150 would not be popular, and that only 10,000 a year might be sold, and might end up collecting dust on the parking lots. Where they wrong with that prediction!
Lets hope that Ford has a heavy duty F-250 EV truck planned for 2026! I think they will need it!
Fred.
Cptnvideo wrote:
There will also have to be additional registration fees imposed to offset the loss of revenue of taxes on fuel.
vern kelly wrote:I see the added weight as more of a positive than negative. Yes, bigger batteries means more weight, but more importantly it means more range. Rather doubt the added weight will be a stability issue---battery packs are generally positioned very low in the chassis. EV motors produce massive amounts of torque and HP, so pushing this additional weight around is certainly not an issue. The added momentum should improve regenerative braking. I see more pros than cons.otrfun wrote:Also cannot find any publication of the curb weight. It must be a very heavy battery pack to boast that kind of range which will affect registration fees and insurance rates negatively. (GVWR rating)Price tag must be very high and charge time.
Interesting, 8 bolt axles/wheels and 2700 lbs. of payload. 14k tow capacity.
Also, the airbag suspension, I assume, probably has a "low-rider" mode which reduces drag to extend range on the freeway.
Pretty impressive. It'll be very interesting to see how far it can tow 14k though.
The Ford EV weighs over 6500, and the gmc hummer an obscene +9000 pounds which is almost as much as my 1998 Ram with my 10 foot Lance camper on board!
A new F350 dually curb weight is in the 7200 lb range (gas) as a comparison with well over 4000 pounds payload capacity.
time2roll wrote:Bionic Man wrote:Can people get excited about the additional capabilities of the EV RAM vs the competition without getting criticized?
I’m not sure why you are so adamant in your defense of EVs as TVs. The simple fact is they aren’t ready for prime time for the vast majority of users, and won’t be for the foreseeable future.
Is there not enough anger over in the gas vs diesel thread?
Bionic Man wrote:
How many units comprise “a whack load”? Because in all of my travels I’ve only seen one EV towing a trailer. That was a Tesla towing a 23’ wake boat in Boulder CO, and the owner said he tows from town a very short distance to the lake.
