Perrysburg_Dodg
Jun 22, 2015Explorer
Truck Trend
prnewswire.com
autoblog.com
So lets see if they write about Ford or GM their Gods? But if it's anything good about FCA/Ram they have it all wrong? OK good to know :R
"Ram claims that this huge figure is the most torque ever available in a mass production vehicle, and it tops the 2015 model by a healthy 35 lb-ft. The added grunt comes thanks to adjustments to the fuel delivery and the turbo's boost, and to better handle things, the rear axle gear now is held with 16 bolts, rather than 12. The tweaks also push the tow rating to an SAE J2807-certified 31,210 pounds, which is absolutely monumental."
Note the highlighted part, Ram claims, not Alpar or Truck Trend or anyone else Ram claims! also note this "2016 Ram 3500 crushes the competition with up to 31,210 pounds of SAE J2807-spec. towing capacity, beating the closest competitor by more than two tons" without have to strip the truck of you know pesky things like a spare tire, radio, all seats but the drivers and the center console! Shame they can't play by the rules.
As far as who gets to the top first, if that is all you have to hold on to you can have it, the Ram will settle with being to the top a few minutes after you.
Don
prnewswire.com
autoblog.com
mich800 wrote:Yep VM screwed up but FCA had the balls to stand up and say they screwed up and will repair the affected trucks when the rod lets loose. Beats having your ignition turn off and people dying don't you think.
"Ram went from 12 to 16 hardened bolts on the rear axle ring gear"
That is just so now they only need to properly torque 75% of the bolts and still have 12 tightened to spec.
Don
44,071 PostsLatest Activity: Aug 30, 2026
